Protective ground circuit
Source: InternetPublisher:两手空空 Keywords: ground Updated: 2020/12/17
Protective grounding is a technical measure that connects the metal casings of motors and household appliances through conductors and metal grounding bodies buried underground
. This method is used in three-phase power supply neutral point ungrounded systems, as shown in Figure 14-1. Its function is that once the insulation of electrical equipment is damaged and leakage occurs
, the human body comes into contact with the live shell. At this time, the resistance of the human body is much greater than the resistance of the ground body (4fl). A large amount of current leaks to the earth through the metal shell, and the voltage
to
the earth can drop below the safe voltage of 36V, thereby ensuring personal safety.
- How to remotely control devices using ESP8266 and LPC2148
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Methods for Eliminating Noise of Brushed DC Motors
- Design and principle analysis of practical electric curtain remote control device
- Design and analysis of the principle of automatic power-off switch during power outage
- Light-controlled circuit design and analysis
- Design and production of wireless multi-location control switch circuit
- Design and analysis of voice control circuit
- Audio interface protection circuit
- Guanghua brand anti-theft doorbell electronic lock circuit
- Differential amplifier emitter negative feedback gain control circuit
- Multi-channel patrol detection control circuit c
- Flashing wall light control circuit
- time control circuit
- DC voltage stabilizing circuit and zero-crossing detection circuit in the indoor unit control circuit of Hisense KFR-25GW-06BP inverter air conditioner
- A tuned circuit composed of one-stage high-frequency amplification and one-stage frequency conversion
- PLC transmission line automatic reclosing control circuit
- Multi-pole leakage protector circuit a
- Wiring c when the leakage protector in the TT system is used for single-phase load
- Wiring a when the leakage protector in the TT system is used for single-phase load
