Three-phase silicon controlled trigger circuit diagram
Source: InternetPublisher:子丑寅卯 Keywords: SCR circuit diagram flip-flop BSP Updated: 2020/09/06
The XMA5000 series regulator sends a three-phase thyristor trigger pulse command and outputs six thyristor phase-shift trigger or zero-crossing trigger control signals, which are used to control the trigger conduction of the main loop thyristor. Using a unique trigger control circuit, it can trigger 3A-1000A one-way or two-way thyristors .
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- Fabrication of multi-cell lithium battery charging circuit
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- LED Driver ZD1680
- A simple positive and negative power supply circuit
- Car Audio Power Supply
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Practical constant current charger-----Constant current charger
- Detailed explanation of mobile phone charger circuit diagram
- Homemade home inverter circuit diagram
- Set timing circuit when power is on
- Smoking Cessation Circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- collector amplitude modulation circuit
- Inductive feedback oscillator circuit
- Capacitive feedback oscillator circuit
- common emitter amplifier circuit
- color discrimination circuit
- Digital stopwatch display circuit
- Home appliance repair signal generator circuit
