455kHz carrier oscillation circuit
Source: InternetPublisher:ohahaha Keywords: carrier wave oscillation circuit transistor Updated: 2021/10/29
Shown is a transistor carrier oscillation circuit. This oscillation circuit is designed at a frequency of 4j5 kHz. Low-frequency transistors can be used. Using
high-frequency transistors is more beneficial to stability.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- Analysis of the basic principle of measuring resistance by bridge method
- How to read resistor color codes? Resistor color codes illustrated
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Causes and solutions for noise in digital Class D amplifiers
- Analysis of the working principle of CMOS/CCD image sensor
- How to build a drag racing timer circuit using a 7-segment display and discrete components
- Ceramic filter structure/working principle/characteristics/application
- Touch circuit design and analysis
- Circuit diagram of an example of differential and integral circuits
- Ultrasonic receiver circuit diagram for echo detection distance
- Capacitive feedback oscillator circuit
- Variable frequency transistor oscillation circuit
- Radio local oscillator circuit
- Simple buzzer circuit 2
- Phase-leading RC phase-shifted oscillator circuit
- Series transistor oscillation circuit
- Transformer coupled feedback oscillation circuit
- Non-adjustable oscillation circuit composed of transistor and crystal oscillator
- 450, 800Hz audio oscillation circuit
