How to connect the load of the capacitive three-point oscillator a
Source: InternetPublisher:通通 Keywords: Oscillator BSP Updated: 2021/02/13
Capacitive three-point oscillator
The capacitive three-point oscillator is an oscillator that uses an LC circuit in the feedback loop to produce the required phase shift and can be used as
a resonant filter that only passes the required oscillation frequency.
①Colpitt oscillator. As shown in the figure (a), when an external load is connected to the output of the oscillator , connect
the load with a small resistance value through capacitor coupling, or connect the load through transformer coupling to eliminate the load.
The effect of resistors,
- Signal diode arrays/configurations, freewheeling diode operation
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What are the parts of the fpga design process
- How do you calculate the value of capacitors in series? Why use capacitors in series?
- Important things to know about PCB routing and how to design the right routing for your PCB
- Using an Op Amp to Drive a Simple and Practical Power Amplifier
- Touch circuit design and analysis
- Circuit diagram of an example of differential and integral circuits
- Digital number selection machine
- Motor overcurrent protection circuit
- Analysis of rectifier circuit types and principles
- DC ammeter
- Diode Balanced Mixer Circuit
- Simple AGC circuit in transistor radio
- Broadband high frequency power amplifier circuit
- Wireless microphone circuit
- Guest arrival signal recognition circuit
- Power phase sequence display circuit
- Sawtooth wave generator circuit (1)
