Circuit composed of ADC 0808-ADC 0809 chips
Source: InternetPublisher:toothache Keywords: ADC chipset digital signal Updated: 2020/02/26
The A/D conversion circuit is a circuit that converts analog voltages into digital encoded signals. The circuit shown in the figure is a circuit composed of ADC0808/ ADC 0809 chips . It can convert analog signals from 0 to 5 V into 8-bit digital signal output.
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- Analysis of the working principle of CMOS/CCD image sensor
- What is the difference between CPLD and FPGA?
- Simple Wired Spy Bug Circuit Built Based on IC741
- Make a flameless electronic candle using simple electronics and LEDs
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Touch circuit design and analysis
- Make a simple AM radio with digital circuit
- Simple LED advertising light circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- Do you know about chipsets targeting short-range optical connectivity applications?
- Design of voice recording and playback circuit module composed of HY560
- Basic structure of multi-channel DA conversion circuit
- Dual 12bit A-D converter chip AD10242 internal structure block diagram
- Rectifier circuit without diodes
- ADC circuit schematic diagram
- ADC701 simple block diagram
- ADC614 internal circuit structure diagram
- ADC circuit
- Use two 8-bit DA chips to form a 6-bit DA converter
