sawtooth wave oscillatora
Source: InternetPublisher:张七岁 Keywords: Sawtooth oscillator potential BSP collector Updated: 2020/04/05
The more commonly used Pockels circuit is shown in Figure (c). First, - Vcc
is added to the base of VT2 through Kl, causing VI2 to conduct, and the capacitor C is charged through R. If k is selected, WR is large. Then the charging time is
longer than the discharging time.
c is quickly charged to the potential The voltage drop of R spit causes the base potential of VTI to become positive through Cl and is cut off.
When c is charging, the collector current gradually decreases, and the power supply voltage passes through the base of the supply and rri, causing VTI to conduct. In this way, the collector voltage of VT1
drops, because the base of VT2 is connected to the collector of VT1 , making \rr2 cut off. Since V12 is turned off, the charge on c is discharged through R until VT2 turns on again when
the emitter potential of VT2 is higher than the base potential . Therefore, periodic sawtooth
waves are generated at both ends of C,
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Analysis of the flow direction of transistor current
- Signal diode arrays/configurations, freewheeling diode operation
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- What is the difference between CPLD and FPGA?
- Causes of PCB deformation How to prevent circuit board bending and warping
- Make a flameless electronic candle using simple electronics and LEDs
- Motor forward and reverse control wiring diagram (2)
- Agricultural small tractor lighting circuit
- Mixer built with analog multipliers
- Diode Balanced Mixer Circuit
- Frequency modulator composed of NE566
- Series crystal oscillator
- Double gate field effect transistor high frequency amplifier circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Three primary color display circuit
- Digital stopwatch display circuit
