A common-emitter transistor amplifier has an output signal in the opposite phase to the input signal, so it is also called an inverting amplifier. If this
circuit is used to amplify pulse signals, it also functions as an inverting amplification. Logically speaking, this circuit is a "Non-one circuit, that is, a "Non gate".
The picture shown is a NOT gate made of integrated circuits. The gate circuit, that is, the inverter, has the phase of the output signal opposite to that of the input. The input signal is a positive polarity pulse
and the output is a reverse polarity pulse.
The gate circuit is the basic unit circuit in the logic signal processing system. It has DTL type and TTL type . and C- MOS types. DTL is
the abbreviation of Diode Tranaistor Logic (diode transistor logic). TTL is the abbreviation of Transistor Transistor Logic (transistor transistor
logic). The difference between these two logic circuits is that the DTL circuit uses diodes as the input circuit. TTL uses transistors as input
circuits. C-MOS is the abbreviation of Complementary MetaJ Oxide Semiconductor. This circuit is mainly a logic circuit
composed of C- MOS field effect transistors .
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Diode-based clipping circuit
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Causes of PCB deformation How to prevent circuit board bending and warping
- How to build a triangle wave generator using an op amp and discrete components
- Tutorial on building a NOT gate using BJT transistors
- Summary of knowledge points of multiplexer
- Star finder battery indicator circuit
- LED Bicycle Lights
- Circuit diagram of a differential amplifier circuit
- Physiotherapy ventilator circuit
- Agricultural temperature control circuit
- soil content measurement circuit
- Greenhouse temperature control circuit
- Farmland irrigation automatic control circuit a
- Junction field effect transistor mixer circuit
- Varactor Diode Frequency Modulator
- Inductive feedback oscillator circuit
- Wireless microphone circuit
- Small current generator circuit
