Local oscillator and equivalent circuit a
Source: InternetPublisher:MartinFowler Keywords: oscillator equivalent circuit oscillator circuit Updated: 2020/09/18
Local oscillators mostly use common collector circuits above 1GHz, which are not prone to low-frequency self-oscillation. Usually the local oscillator signal
is added to the mixer through a buffer amplifier stage to reduce the impact of mixing on the frequency stability of the local oscillator. Shown is the local oscillator and
equivalent circuit, which is a common collector capacitor feedback oscillation circuit . When the value of the tuning voltage changes, the capacitance of the varactor connected in the oscillation circuit
changes, resulting in a change in the oscillation frequency, thus enabling channel selection.
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- What is a RADAX motor?
- A small improvement to the temperature and water level indicator alarm
- DC motor drive circuit composed of L293D
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Design and analysis of the principle of automatic power-off switch during power outage
- Do-it-yourself trial production of phase failure protection device
- Design and manufacture of three-phase motor protection circuit
- Delay switch made with LM431
- Ultra-short wave item left behind reminder alarm
- Call for help alarm circuit
- Wien bridge oscillatorb
- Square wave oscillator
- One of the automatic periodic switching circuits
- Self-excited intermittent oscillator basic circuit
- CR scanning oscillator with wide variation range
- Solenoid water valve automatic control circuit
- Baby wet alarm circuit (2)
- Incandescent lamp flash circuit using LM3909 as oscillator
