Broadband operational amplifier circuit structure
Source: InternetPublisher:他们逼我做卧底 Keywords: Broadband operational amplifier circuit circuit structure frequency range Updated: 2021/10/16
The structure of the wide-band high-output operational amplifier circuit is shown in the figure. It is an operational amplifier composed of separate components such as differential signal input circuit (VT1, vn), excitation
amplifier V13 and complementary push-pull output stage (VT4, VT5). . There is direct coupling between all stages, and the frequency range
of the amplified signal starts from DC, and the high frequency can reach 30 MHz. This circuit is suitable for signal measurement. If the transistor is selected with good high-frequency
performance, it can reach IOH, and the frequency range of the amplifier can be extended.
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Ideal characteristics of operational amplifiers/pin configurations/gain types/primary applications
- Analysis of the basic principle of measuring resistance by bridge method
- What are the main types of resistors? Detailed explanation of the functions and uses of resistors
- What are the parts of the fpga design process
- Why Do Amplifier Fuses Blow? How Do You Prevent Amplifier Fuses from Blowing?
- Why use PWM? What are its advantages?
- Make a simple AM radio with digital circuit
- LED Bicycle Lights
- Experiment and production of NE555 time base integrated circuit
- 3-bit AD converter circuit structure
- T flip-flop circuit structure and its input-output signal waveform
- Circuit structure and equivalent circuit of downconverter a
- Low output impedance operational amplifier circuit
- Current amplifier circuit structure diagram
- Three basic bias circuit structures c
- Broadband meter driver amplifier using OP amplifier with high frequency characteristics
- LT1220 high-speed operational amplifier circuit
- Broadband Op Amp Circuit
- Low Noise Broadband Op Amp Circuit
