Driver drowsiness alarm circuit
Source: InternetPublisher:张七岁 Keywords: Alarm circuit switch BSP Updated: 2020/07/29
The circuit shown is a sleep alarm circuit. Figure a shows an alarm switch composed of a mercury switch
and a plug. The mercury switch is
composed of an electrode installed in a glass shell and mercury injected into it. b is the alarm circuit
, which uses the lighting power supply
(or battery cabinet j1) on the motorcycle (or car) instead. The alarm sound does
not need earplugs. Instead, it uses HTD
piezoresistive sounding components with feedback electrodes.
Use At this time, put the part a in Figure 13-12 on the driver
's head and put on the earplug machine. The position of the mercury switch
should be adjusted according to the habitual position of the driver's head
so that the circuit is not connected. When the driver is sleepy,
his head Shake your head or tilt your body to cause
the mercury in the mercury switch to flow, and turn on the mercury switch .
VT will work. HTD will immediately sound an alarm. The sound frequency of this
circuit is 4kHz, which is extremely sensitive to human hearing. Adjust iookfl, resistance, you can Change the volume of the sound.
- Example of LED AC drive circuit
- Measurement and analysis of automatic emergency lighting circuit
- Use NE555 to make a lighting and sound changing circuit
- Infrared remote control device circuit
- Use NE555 to make a touch self-extinguishing table lamp
- Lighting sound-activated switch circuit using thyristors Part 3
- Gas and smoke alarm circuits with intermittent alarms
- Automotive LED driver circuit diagram using LT3486
- Seven-way flashing light string circuit
- Mains undervoltage and overvoltage alarm circuit 2
- Analysis of rectifier circuit types and principles
- Rice mill circuit
- Chicken supplementary light to increase egg production rate circuit
- DC ammeter
- Integrated synchronous detector composed of analog multiplier MC1596
- Simple AGC circuit in transistor radio
- Double gate field effect transistor high frequency amplifier circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Three primary color display circuit
- Various signal generator circuits
