Hall element and motor starting principlea
Source: InternetPublisher:兰博 Keywords: Motor Hall element coil Updated: 2021/07/20
The driving principle of the Hall element and the motor is shown in the figure. When the Hall element Hl is aligned with the N pole of the rotor magnet, IC2 outputs a high
level, VT3 is turned on and the output current goes to ground through L1 and k, and the coil generates a magnetic field to drive the rotor; when Hl is aligned with the S pole, IC2 outputs a negative level. When voltage VT4
is turned on, reverse current appears in k and Li, which also generates a magnetic field that drives the rotor to rotate. In the same way, when H2 is aligned with the S pole, or
when aligned with the N pole, a forward or reverse current will flow through L3 and L4 under the control of the ICl circuit, generating a driving magnetic field in the same direction.
- How to use a microcontroller to control a servo motor?
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Car ice warning circuit sharing
- Tutorial on making your own remote-controlled robotic arm
- Design of an autonomous plant watering system using ATtiny85
- A small improvement on the ordinary refrigerator motor starting circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of voice control circuit
- Do-it-yourself trial production of phase failure protection device
- Password type motorcycle anti-theft device
- Simple timing control circuit
- fire smoke control circuit
- Water dispenser double sheet control circuit
- Electromagnet control circuit
- Assembly line outage monitoring circuit
- PLC transmission line automatic reclosing control circuit
- Detection and control circuit of electromagnetic stove
- Sprinkler control circuit using AC motor
- Small power electric heater temperature detection control circuit
- Small signal to large current photoelectric control circuit
