Internal structure of CD4017
Source: InternetPublisher:武林萌主 Keywords: CD4017 power supply oscillator headphones Updated: 2020/11/06
Shown is a pulse signal hypnotic circuit. As can be seen from the figure, the circuit is composed of a pulse oscillator , a flip-flop CD4017 and
a pulse output circuit BGI. Plug in the headphone power supply to turn it on. At the moment of power-on, the power supply provides a reset pulse to the CD4017 trigger through cl to
reset the CD4017. So the CD4017@ pin outputs a high level, BG1 is turned on, and the LED lights up. At the same time, the pulse oscillator
composed of CD4069 starts to oscillate. This signal is sent to the CD4017@ pin as a clock pulse. After the internal trigger circuit works,
The pulse signal output from the @ pin is amplified by BGI and added to the earphones . It is like raindrops, eye-catching. The internal function diagram of CD4017 and
the signal waveforms of related pins are respectively
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- How do Zener diodes protect circuits?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Principle set of zero-crossing detection circuit advantages and disadvantages
- Transfer characteristics of BJT, how to apply Shockley equation?
- DIY a decorative lamp
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Causes of PCB deformation How to prevent circuit board bending and warping
- Important things to know about PCB routing and how to design the right routing for your PCB
- Photosensitive automatic dimming desk lamp circuit and principle
- Underarm odor treatment device circuit diagram
- Power outage sound and light alarm circuit
- 7MHz high frequency carrier oscillator
- crystal controlled oscillatora
- Pulse signal hypnotic circuit
- Use CD4011 and CD4017 to make a touch-type five-speed dimmer
- Car food warmer circuit
- Delay bedside lamp circuit with hypnotic device
- Switching circuit consisting of oscillator and triac
