source follower
Source: InternetPublisher:smallembedded Keywords: Field effect transistor BSP resistor load resistor Updated: 2021/04/15
source follower
Shown is a source follower (buffer amplifier) circuit using a differential input buffered operational amplifier circuit that can be used in
impedance conversion circuits. A field effect transistor
(VTl)
is used in the circuit to form a source follower, which is similar to the emitter follower of a transistor.
The input impedance of the field effect transistor is very high. The source of the field effect transistor is connected to a transistor VT2, and the base of the transistor It is determined by the voltage dividing resistor to form
a constant current circuit. In order to make the gain of the circuit as close to 1 as possible. It is necessary to use a transconductance field effect transistor and a larger load resistor . Using
this circuit structure, + is connected to the source circuit with VT2, which is equivalent to increasing the load resistor to meet the requirements of the circuit.
- Signal diode arrays/configurations, freewheeling diode operation
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- What does a rectifier do? What is the process of rectification?
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Share an interesting LED decoration project
- Ceramic filter structure/working principle/characteristics/application
- Summary of knowledge points of multiplexer
- Experimental circuit based on 4040 binary adder counter
- Simple LED advertising light circuit
- electromagnetic field sensor
- Voice controlled flash LED light circuit diagram
- Excellent performance household inverter power supply circuit
- Self-defense anti-riot circuit
- Crop anti-frost circuit
- Particle clogging alarm circuit of wheat seeder
- Poultry warming temperature control circuit
- Schiller oscillator circuit
- superheterodyne radio circuit
- Motorcycle flash light circuit
