The working principle of common collector amplifier circuit
Source: InternetPublisher:国民男神经 Keywords: amplifier circuit common collector Updated: 2021/01/14
After the signal passes through the common collector amplification circuit , it outputs a signal that is in phase and has almost the same amplitude (slightly smaller than the input signal ). Its working principle is
shown in Figure 1-15. It can be seen from the figure that U^TUk+U-H, then it can be seen. U Kuang U^-Uc, and the voltage Ube between the base and emitter of the transistor is much smaller than the voltage
on the load , so U m is almost equal to U^. In this circuit, only the current is amplified, so it is often
used as a current amplifier.
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- How are diodes made using semiconductors?
- Analysis of the flow direction of transistor current
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- How does a series arrangement of Zener diodes affect the electrical behavior?
- What is an ac to dc transformer in circuit design
- How to identify common mode interference? Methods to eliminate common mode interference
- Analysis of the basic principle of measuring resistance by bridge method
- Analysis of the working principle of CMOS/CCD image sensor
- Tutorial on building a NOT gate using BJT transistors
- Sound speed measurement circuit
- FM intermediate frequency amplifier circuit composed of ceramic filters
- Single tuned amplifier circuit
- Current amplifier circuit structure diagram
- Practical amplifier circuit g composed of operational amplifier LM386
- Practical amplifier circuit c composed of operational amplifier LM386
- Two-stage resistor-capacitor coupling amplifier circuit
- The working principle of common collector amplifier circuit
- Three types of transistor amplification circuits and their characteristics - common base circuit
