Two-stage resistor-capacitor coupling amplifier circuit
Source: InternetPublisher:赔钱虎 Keywords: Amplification circuit resistor-capacitor coupling BSP capacitor Updated: 2021/02/17
In addition to DC-coupled amplifier circuits, coupling amplifier circuits also come in the form of resistor-capacitor coupled amplifier circuits and transformer-coupled amplifier circuits.
①Resistance-capacitance coupling multi-stage amplifier circuit. The figure shows a two-stage resistor-capacitor coupling amplifier circuit. It can be seen from the figure that between two single-stage amplifiers
, the AC signal is transmitted from the first stage to the second stage through the coupling capacitor C2. The "load" of the first stage is the "input resistance" of the second stage
. After the AC signal is amplified by the first stage, it is sent to the second stage by the coupling capacitor cz, and the signal voltage falls on
both ends of the input resistor of the second stage. This is the meaning of resistance-capacitance coupling.
The resistance-capacitance coupling method has two outstanding advantages - the coupling capacitor has a DC blocking effect, so the working points of the amplifiers at each stage are independent of each other,
which brings great convenience to the design and maintenance of the circuit: second, when the signal frequency has been Under known conditions, appropriately selecting a coupling capacitor with a larger capacity
can reduce the loss of the signal on the capacitor to improve transmission efficiency.
Disadvantages of the resistance-capacitance coupling method: it cannot amplify signals with very low frequencies. Because, for signals with very low frequency, the capacitive reactance of the coupling capacitor
is very
large, and the signal transmission efficiency is too low. The
resistance-capacitance coupling method is mostly used in small signal amplification circuits of various frequencies .
- What does a rectifier do? What is the process of rectification?
- What factors are related to the hysteresis loss of the transformer? Can the hysteresis loss be reduced?
- How to identify common mode interference? Methods to eliminate common mode interference
- Principle set of zero-crossing detection circuit advantages and disadvantages
- What are the classifications of filters?
- RC filter explained in detail
- What is a D flip-flop and how does it work?
- How to build a triangle wave generator using an op amp and discrete components
- Introduction of TDA4863J/4863AJ TV field scanning IC
- Experimental circuit based on 4040 binary adder counter
- Motor overcurrent protection circuit
- strain sensor
- Smoking Cessation Circuit
- Peanut and melon seeds roasting machine circuit
- Rural vegetable greenhouse lighting circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Amplitude modulation circuit composed of MC1496
- Schiller oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Guest arrival signal recognition circuit
