DC and AC paths b of common collector amplifier circuit
Source: InternetPublisher:MartinFowler Keywords: Amplification circuit common collector BSP Updated: 2021/05/24
(3) DC and AC paths of common collector amplifier circuit
When analyzing the common collector amplifier circuit
, it can also be divided into two paths, DC and AC, as shown in the figure.
The DC path of this circuit is a circuit in which the power supply provides DC bias voltage to the transistor. Whether the transistor works in the amplification state or the switching state
is mainly determined by its bias voltage. This circuit is also the circuit that provides energy to the transistor.
The AC path is a circuit that acts on AC signals. The capacitor can be regarded as a short circuit to the AC signal, and the internal resistance of the power supply can also be regarded
as a short circuit to the AC signal.
- The unidirectional conduction current of the diode, the diode and its common uses
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- What is the relationship between capacitance and impedance in an AC circuit? How do you calculate the impedance of a capacitor?
- How do Zener diodes protect circuits?
- This article will tell you the hard requirements of operational amplifiers
- Analysis of the basic principle of measuring resistance by bridge method
- How to read resistor color codes? Resistor color codes illustrated
- What types of power field effect tubes are there? Selection criteria for power field effect tubes
- Basic characteristics/working principles and application circuits of tunnel diodes
- Share an interesting LED decoration project
- Ultrasonic blind pathfinder circuit
- High-efficiency speaker circuit for rural stage
- Double detuned loop frequency discriminator circuit
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Three primary color display circuit
- Guest arrival signal recognition circuit
