The working principle of common emitter amplifier circuit a
Source: InternetPublisher:newrudeman Keywords: Common emitter amplifier circuit output voltage Updated: 2020/01/14
After the signal passes through the common emitter amplification unit circuit, it outputs an inverse amplified signal. Its working principle is shown in the figure. When analyzing, we
can consider the change curve of the input signal as the change curve of the input current . In the 1/4 cycle, the current is increasing. According to
the amplification function of the transistor IC-18IB, it can be seen that the current is also increasing. According to Ohm's law URC=ICRC, seven f. Then URC f, then from the output voltage
UR
on the load RL , = VCC-URC can be obtained·sevent, URC t, Vcc remains unchanged, Uk, J. That is, the output curve is as shown in Figure 1-7 (a)
. The other cycles are similarly shown in Figure (b) (c) (d). It can be seen that the output voltage is opposite in phase to the input voltage.
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- Analysis of the working principle of CMOS/CCD image sensor
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Diode-based clipping circuit
- TL494 pin functions/configuration/ratings/operating conditions/layout diagram
- Share a Motorola amplifier circuit
- Experimental circuit based on 4040 binary adder counter
- Star finder battery indicator circuit
- Experiment and production of NE555 time base integrated circuit
- Purpose and composition of amplifier circuit: low frequency voltage amplifier amplifier circuit
- TMPO1 internal functional block diagram and basic application circuit
- AN6071 application circuit b
- Series DC regulated power supply
- Industrial static elimination circuit
- The working principle of common emitter amplifier circuit a
- Charging circuit using transformer step-down method
- Output voltage expansion circuite
- Stabilized power supply with continuously adjustable output voltage
- Applications to increase output voltage (b)
- Ultra-low quiescent current ZXSC100 application circuit analysis
