Secondary circuit using transistor as silencer
Source: InternetPublisher:spectrum Keywords: transistor headphone BSP Updated: 2021/05/02
The headphone circuit is one of the essential audio circuits for MP3/MP4 machines. Figure 9-31 shows a headphone circuit using transistors as muffler tubes
. The output audio signals (L, R) are sent to the headphone interface through coupling capacitors CT14 and CT16. There are muffler control
transistors . Q3, these two transistors are controlled by Q4. Q4 is a PNP transistor . When the base of Q4 has a low-level control signal, Q4 is turned
on, so the collector voltage of Q4 provides high voltage to the bases of Q2 and Q3 respectively through R88. level, Q2 and Q3 are turned on. The audio signal is shunted to the ground by Q2 and
Q3, with no output and signal, and is in a mute state. When no headphones are plugged in, the ④ pin of the headphone interface is connected to the right channel, and the right channel audio
signal is sent to the speaker amplification circuit. When headphones are plugged in, the signal to the speakers is cut off.
In addition, the ground terminal of the headphone interface also serves as the antenna of the FM radio circuit . When the headphones are inserted , the shielding layer of the wire acts as
the external antenna of the FM radio to receive FM broadcast signals.
- Using TDA2822 to do direct coupler output experiment
- Single-ended Class A amplifier using gallstone composite tube design
- DIY 50W Gallstone Amplifier
- Make a pocket amplifier with 8550 and 8050
- Converting a microphone preamplifier (RJ4558) into a headphone amplifier
- 6AS7 tube amplifier
- Stereo phono amplifier circuit with bass control composed of LM1877
- 2W×2 power amplifier circuit using LM1877
- LM4820-6 audio power amplifier circuit
- Application of BTL power amplifier circuit composed of LM3886
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- Agricultural temperature control circuit
- Chicken supplementary light to increase egg production rate circuit
- Rural vegetable greenhouse lighting circuit
- Domestic KD8041 integrated phase locked loop
- ring amplitude modulation circuit
- Schiller oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Various signal generator circuits
