DC motor drive circuit
Source: InternetPublisher:aytwartoofyoroo Keywords: DC motor bridge drive circuit Updated: 2024/10/14
The bridge drive circuit in the figure below has the following features: first, it triggers the motor to run at a low level; second, the control terminals A and B have a trigger lock function; third, it has multiple protections, such as the trigger lock of D1 and D2, and the power tube collector protection of D3~D6. Therefore, this circuit has only three input states valid, and the motor still has five working states. The function of D1-D2 is: if A is at a low level, BG1, BG2, and BG5 are turned on. The high level of the collector of BG2 will block the input of the B terminal through D2 to ensure that BG6 is turned off. If this circuit is triggered by a TTL circuit, an open collector gate circuit must be selected.
- What are the advantages of solid-state relays? Solid-state relay insulation monitoring design scheme
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to build a simple tachometer using an infrared reflectance sensor
- Homemade Bluetooth controlled car using HC-05 Bluetooth module to communicate with mobile phone
- An automated model railroad layout project using a microcontroller
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Motor self-starting circuit
- Motor control circuit for starting and running without phase loss
- Simple phase failure protection circuit composed of intermediate relay
- Chicken farm photoelectric control circuit
- time control circuit
- Stapler control circuit
- Microwave oven control circuit
- Three-phase stepper motor control circuit
- Bedside touch light detection control circuit
- Timing and fire power control circuit
- Temperature detection control circuit of electric hot water bottle
- Forward and reverse control circuit of micro DC motor b
- Basic structure of power factor control circuit
