Philips 170B LCD monitor inverter circuit
Source: InternetPublisher:赔钱虎 Keywords: LCD display Philips inverter circuit BSP Updated: 2021/01/18
The figure below shows the inverter circuit of Philips 170B LCD monitor . As can be seen from the figure, it is mainly composed of the inverter control chip Ul and the startup
power supply circuit Ql and Q2. It is composed of switching circuits Q3 and Q4, high-voltage transformers and resonant circuits. It has 2 sets of high-voltage transformers to
supply power to 4 backlight tubes.
DC 18 V supplies power to the inverter. The start/stop control signal (ON/OFF) is first added to the base of the 02 transistor. The start pair is high level,
Q2 is turned on, and the collector voltage of Q2 decreases, so Ql (PNP type transistor) is also turned on, the +18 V power supply
supplies power to the control chip UI @ pin through Q1, Ul starts, and the @ pin outputs a pulse signal to drive Q4, and Q4 provides a pulse signal for the gate of the field effect transistor Q3. In addition to providing a driving signal to the base of Q14, the D-pole output of Q3
is also added to the @ pin of the high-voltage transformer through the inductor Ll. The @ and @ pins are connected to
the collectors of the two oscillation transistors. C16 is the resonant capacitor. The high-voltage transformer oscillates under the action of the driving signal. T1 is a step-up transformer, and
the output peak value of the secondary @ and ⑦ pins can reach 700-800 V. This signal supplies power to both lamps simultaneously through the lamp holder.
When a problem occurs in this circuit, you can first check the output of the high-voltage transformer. As long as the oscilloscope probe is close to the core of the high-power transformer
, the oscilloscope will sense a strong AC signal. If there is no signal, it means that the high-voltage transformer has no output. Then check whether the signal output of pin ⑦ and pin @ of the control chip
is normal. There should be pulse signal output in normal working state. If there is output, check
whether Q3, Q4, Q14, Q8 and the oscillation transistor are good. If there is no signal, check whether the +18V power supply and Ql, Q2 and other circuits are in good condition.
- How about the boost converter TPS61299?
- 220V Remote Load Monitor
- Recommended circuits for different power on times of LM4911
- Op amp power supply decoupling bypass measures
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- Current/voltage conversion circuit using current converter
- Power supply circuit that can reduce LM317 ripple
- Constant current charger using light emitting diode as voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- electromagnetic field sensor
- Analysis of rectifier circuit types and principles
- Electronic thermometer circuit
- High-efficiency speaker circuit for rural stage
- Egg heating control circuit
- DC ammeter
- AC voltmeter
- Double detuned loop frequency discriminator circuit
- Double gate field effect transistor high frequency amplifier circuit
- Fault signal trip circuit
