The high voltage output of the inverter forms the circuit
Source: InternetPublisher:刘德华河北分华 Keywords: Inverter high voltage BSP Updated: 2020/01/24
The high-voltage output forming circuit is composed of dual transistor Q4, step-up transformer Tl, capacitor C3 and other components. This is a typical transformer-
coupled self-excited oscillation circuit. The circle shows the high-voltage output forming circuit of the inverter .
The circuit relies on the correct connection of the same terminals of the primary and secondary windings of the transformer to meet the phase conditions of self-excited oscillation, that is, to meet the positive feedback conditions. To satisfy the amplitude condition, firstly, the circuit
parameters
should be reasonably selected so that the amplifier can establish a suitable static operating point. Secondly,
the number of turns to increase the coupling degree between it and the primary winding to obtain sufficiently strong feedback. quantity. The amplitude stabilization effect is achieved by utilizing the nonlinearity of the transistor
. The high voltage induced by the secondary winding of Tl supplies power to the backlight through c5, C6 and connector CN2.
- The basic principles of power supply design. What are the key components of a power supply?
- How about the boost converter TPS61299?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Step-down power supply for driving relays
- Constant current LED lamp driver circuit with soft start and anti-shock
- How to use SBR to improve power conversion efficiency
- Miniature polarity reversal power supply using MAX1721
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Detailed explanation of mobile phone charger circuit diagram
- Rice mill circuit
- DC ammeter
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Audio function generator composed of ICL8038
- Series crystal oscillator
- Crabo oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Second-order active band-stop filter circuit
- color discrimination circuit
- Guest arrival signal recognition circuit
