switching oscillator circuit
Source: InternetPublisher:MartinFowler Keywords: switch oscillator circuit BSP switching transistor Updated: 2020/07/18
Switching oscillation circuit
The switching oscillation circuit is mainly composed of the switching field effect transistor Qlol, the switching oscillation control integrated circuit Ul01 and related circuits.
The figure shows the switching oscillation circuit.
When starting up, the 300 V DC voltage rectified and output by the 220 V AC voltage is added to the drain D of the switching transistor Ql01 through the primary winding ①~@ pin of
the switching transformer Tl01. The source S of the switching transistor is grounded through RⅢ, and the gate G is controlled by the ⑥ pin of the switching oscillation integrated circuit U1ba
The 300 V DC voltage provides a starting voltage for the ① pin of U101, which starts the oscillator in U101 and provides an oscillation signal for the gate G of the switching transistor
Qlol . Then the switching transistor Q10l starts to oscillate, causing the switch transformer to activate the primary coil of T101. generates switching current. The induced current is generated in the secondary windings ③ and ④ of the switching
transformer. The output of ③ is rectified and filtered to form a positive feedback voltage and is added to
the ⑦ pin of Ul0], thereby maintaining the operation of the oscillation circuit and allowing the switching power supply to enter normal operation. state.
- Benefits of Wide Bandgap Technology for Power Converters
- Step-down power supply for driving relays
- Recommended circuits for different power on times of LM4911
- Basic connection circuit of signal and power supply composed of ISOll3
- Driving circuit that controls LED brightness using PWM signal
- Transformerless AC-DC constant current LED driver circuit
- Constant current LED lamp driver circuit with soft start and anti-shock
- Miniature polarity reversal power supply using MAX1721
- A low-cost, high-reliability battery charger for electric vehicles
- Battery powered switching circuit diagram
- Motor forward and reverse control wiring diagram (2)
- electromagnetic field sensor
- soil content measurement circuit
- Peanut and melon seeds roasting machine circuit
- Greenhouse temperature control circuit
- Soil water shortage prompt circuit
- AC voltmeter
- Integrated synchronous detector composed of analog multiplier MC1596
- Crabo oscillator circuit
- color discrimination circuit
