GH-75 hydrogen atom welding machine circuit
Source: InternetPublisher:酷到被通缉 Keywords: Electromechanical BSP Updated: 2021/12/21
Hydrogen atom welding utilizes the arc generated between two non-melting tungsten electrodes WG protected by hydrogen gas, and the welding wire
melts and welds the workpiece in the area protected by hydrogen. Since hydrogen has a strong cooling effect on the arc
, making it difficult to pass the arc, the welding power source requires an
arc starting voltage higher than 300V . The secondary no-load voltage of the GH-75 hydrogen atom welding machine is 300V, the working
voltage is 100V, the rated welding current is 75A, the welding current adjustment range is
20~100A, and the rated output is 22. 5kV. A. The rated duty cycle
is 65%, the efficiency is 75%, the power factor is 0.36, and the tungsten electrode diameter is
1.5~3mm. The circuit of
GH-75 hydrogen atom welding machine is shown in the figure.
In the figure, the solenoid valve Y is used to control the on and off of hydrogen;
the intermediate relay KAz is used to control the continuation of the welding circuit; the reactor L is
used to adjust the welding current; the foot switch SB2 is used to disconnect the welding power supply.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- How to Make a Soft Latch Circuit
- Using Lead-acid Battery as Power Source for Walkman
- Recommended circuits for different power on times of LM4911
- Transformerless AC-DC constant current LED driver circuit
- LNK304 non-isolated LED light string driver circuit
- Dual forward converter schematic diagram
- Boost drive circuit composed of RT8450
- 0.7~24V continuously adjustable current limiting power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- Motor forward and reverse control wiring diagram (2)
- strain sensor
- Excellent performance household inverter power supply circuit
- Self-defense anti-riot circuit
- Agricultural small tractor lighting circuit
- Poultry warming temperature control circuit
- Crabo oscillator circuit
- superheterodyne radio circuit
- Digital stopwatch display circuit
- Small current generator circuit
