Timer alarm circuit diagram for car or room
Source: InternetPublisher:偷熊计划 Keywords: timer alarm circuit circuit diagram Updated: 2021/02/25
S1 in the circuit is the door control photoelectric switch or the luggage room light control switch. Point A is the positive operating voltage when it is closed. If S2 is closed, regardless of whether S1 is closed or not, the output terminal voltage U3 is high, the transistor is turned on, the relay does not pull in, and the light-emitting diode LED does not light up.
S2 is a normally open contact. If S1 is closed (the door is open), Cl starts to charge slowly through Rl. Within a certain period of time (can be adjusted by potentiometer RP, no more than 60s), U3 suddenly becomes low level, so the relay is turned on and the alarm works. If S2 is closed during the alarm, U3 is high level again and the relay is released.
- A simple magnetic switch circuit sharing
- Tutorial on making your own remote-controlled robotic arm
- Use your smartphone to turn on/off the power in your home
- Controlling LEDs with Node-RED in Raspberry Pi
- Tutorial for building a remote-controlled Arduino Air-Boat
- One-way rotation circuit of motor controlled by contactor
- Design and principle analysis of practical electric curtain remote control device
- Simple three-phase motor phase loss protection circuit
- Delay switch made with LM431
- Password type motorcycle anti-theft device
- Particle clogging alarm circuit of wheat seeder
- Frost alarm circuit
- Verbal reversing alarm circuit (2)
- Water full alarm circuit
- Fireproof and anti-theft telephone intelligent alarm circuit-voice circuit
- Home stolen phone automatic alarm circuit
- High voltage alarm circuit
- Delay circuit using operational amplifier
- 555 equal time interval timer
- Timer with 10S fixed preset time
