Frequency converter step operation and inching operation circuit
Source: InternetPublisher:newrudeman Keywords: Frequency converter BSP Updated: 2021/02/09
In the figure, REV is the reverse run and stop command terminal . FWD is the forward running and stop
command terminal, and JOG is the jog terminal. CM is the common terminal for contact input, and X4 and x5 are acceleration/deceleration time selection terminals .
Through switches Sl, sz. Four types of acceleration/deceleration time can be selected.
In some production processes, downtime is not allowed. Once the frequency converter trips due to a fault during variable frequency operation , it must
switch to power frequency operation. In addition, some occasions require switching between power frequency operation and variable frequency operation.
- How to use a microcontroller to control a servo motor?
- A simple door handle touch alarm circuit
- A small improvement to the temperature and water level indicator alarm
- Squirrel cage asynchronous motor reverse braking control circuit
- One-way rotation circuit of motor controlled by contactor
- Design and analysis of a four-bit remote control component capable of remote reset
- Motorcycle anti-theft device circuit design
- Infrared detection alarm
- Car audio system anti-theft circuit
- "Watchdog" anti-theft alarm circuit
- Electronic thermometer circuit
- Ultrasonic blind pathfinder circuit
- Homemade disinfectant circuit
- Crop anti-frost circuit
- Agricultural spraying and insecticide control circuit
- Mixer built with analog multipliers
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- superheterodyne radio circuit
- Small current generator circuit
