300kHz Signal Generator
Source: InternetPublisher:失踪的猫 Keywords: Signal Generator Updated: 2024/09/29
As shown in the figure, it is a 300kHz signal generator. It is composed of VT1, T1, VD4 and related components to form a voltage-controlled oscillator. The voltage-controlled oscillator adopts LC collector tuning. VTl is an oscillator tube. The tuning circuit is composed of variable capacitance diode VD4, capacitors C3~C6 and the inductance of the 1~3 windings of the variable capacitance diode T1. The variable capacitance diode VD4 works in reverse bias, and the control voltage is added to the negative end to change its capacitance. The oscillation signal is output by the 6~7 windings of Tl. Among them, C6 is a frequency fine-tuning capacitor. VD3 stabilizes the working voltage of the oscillation stage, and the stable voltage is 6.8V±0.2V.
Component selection:
Transistor VT1: 3DG6C, β=65~85.
Diodes VD1, VD2: 2CPl4, VD5: 2CK18.
Zener diode VD3:2CWl4.
Varactor diode VD4:2CC5.
Resistors R1: 3.6k, R2: 3.3k, R3: 5.1k, R4: 510Ω, R5: 3.9k, R6: 3k, R7: 100k, all of which are RTX-0.125W.
Capacitors C1, C2: 5μF30V, C3: 51pF100V, C4: 820pF100V, C5: (optional during commissioning), C6: 20pF. Transformer T1: Model L22, A=100.
L1-4: Φ0.29mm, 27 turns, L2-3: Φ0.29mm, 18 turns, L4-2: Φ0.29mm, 9 turns, L5-8: Φ0.29mm, 7 turns, L6-7: Φ0.29mm, 6 turns.
L1-3=292μH, allowable error range: 0~10μH.
- Two common RC oscillator circuits
- An example of LC oscillation circuit
- Multifunctional LC Oscillation Circuit Demonstrator
- Oscillator circuit composed of LM339
- Ultra-high frequency voltage-controlled oscillator constructed with UPC1651
- Pulse wave generator with adjustable duty cycle
- Circuit diagram of adjustable sine/square wave oscillator
- 10/1 frequency range function oscillator
- Driving a light-emitting diode with a basic monostable circuit
- Infrared transmitter circuit using silk screen quartz crystal oscillator
- Various signal generator circuits
- Home appliance repair signal generator circuit
- Staircase wave signal generator circuit
- Voltage signal generator circuit with optical isolation
- Two examples of 60Hz time base signal generator circuit circuit-a
- Sub-audio tone signal generator
- simple tv signal generator
- Sequence signal generator circuit
- 450HZ signal generator
- Various analog sound signal generators
