Lightning protection wiring of oil switch on the pole b
Source: InternetPublisher:王达业 Keywords: switch wiring BSP transformer Updated: 2021/05/06
Lightning protection terminals of pole oil switches.
Pole oil switches are mostly used for line segmentation or transformer matching . Due to its small phase distance and low insulation level, it must
be protected with a pavilion-type arrester or protective gap. Its wiring is shown in the figure. Figure (a) is suitable for
oil switches that are often closed; Figure (b) is suitable for oil switches that are often open. The grounding resistance is not greater than 10,0.
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Driving circuit of switching power supply field effect tube
- Step-down power supply for driving relays
- Basic circuit description of adjustable voltage regulator LM317
- Recommended circuits for different power on times of LM4911
- Transformerless AC-DC constant current LED driver circuit
- Boost drive circuit composed of RT8450
- Power supply circuit that can reduce LM317 ripple
- Design of electric vehicle charger
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Bone hyperplasia treatment circuit
- Smoking Cessation Circuit
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Varactor Diode Frequency Modulator
- Simple AGC circuit in transistor radio
- base amplitude modulation circuit
- Voltage series negative feedback amplifier circuit
- Three primary color display circuit
- Digital stopwatch display circuit
