Wiring f when leakage protector supplies power to single-phase load in TN system
Source: InternetPublisher:失踪的猫 Keywords: Wiring leakage protector power supply BSP Updated: 2021/05/27
TN system, that is, the neutral point on the power side is directly grounded.
In the figure, the TN-C system is a three-phase four-wire system in which the working neutral line N and the protective neutral line PE are combined into a PEN line; the TN-S system neutral line N cannot be connected to the neutral of
other equipment or lines without leakage protectors. Line N is shared and is not allowed to
be connected to the protective neutral line PE, equipment metal shells, wire steel pipes and other metal parts connected to the earth. That is to say,
a system with three phase lines, a general neutral line N and a protective neutral line PE (PE is led separately from the neutral point of the transformer) through the leakage system
is also called a five-wire system.
- The basic principles of power supply design. What are the key components of a power supply?
- How about the boost converter TPS61299?
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Step-down power supply for driving relays
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Simple and practical LED lamp driving circuit
- LNK304 non-isolated LED light string driver circuit
- Dual forward converter schematic diagram
- Adjustable voltage regulated power supply circuit
- Detailed explanation of mobile phone charger circuit diagram
- strain sensor
- Self-defense anti-riot circuit
- High-efficiency speaker circuit for rural stage
- Fish farming thermostatic control circuit
- Varactor Diode Frequency Modulator
- Audio function generator composed of ICL8038
- Parallel crystal oscillator
- Capacitive feedback oscillator circuit
- Differential Amplifier Circuit
- Power phase sequence display circuit
