Wiring a when the leakage protector supplies power to single-phase loads in the TN system
Source: InternetPublisher:MartinFowler Keywords: Wiring leakage protector power supply BSP Updated: 2020/06/01
TN system, that is, the neutral point on the power side is directly grounded.
In the figure, the TN-C system is a three-phase four-wire system in which the working neutral line N and the protective neutral line PE are combined into a PEN line; the TN-S system neutral line N cannot be connected to the neutral of
other equipment or lines without leakage protectors. Line N is shared and is not allowed to
be connected to the protective neutral line PE, equipment metal shells, wire steel pipes and other metal parts connected to the earth. That is to say,
a system with three phase lines, a general neutral line N and a protective neutral line PE (PE is led separately from the neutral point of the transformer) through the leakage system
is also called a five-wire system.
- How to use LM317 as a switch to turn power load on and off
- Power Management Solutions for PoE Switches
- Working principle of LDO voltage regulator, basic circuit diagram of LDO
- TL431 functional pin diagram, DC linear regulated power supply solution based on TL431
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- Recommended circuits for different power on times of LM4911
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Detailed explanation of 5v charger circuit diagram
- Parallel DC regulated power supply circuit diagram
- Low cost and high performance LED constant current power supply
- Inpatient pager circuit
- soil content measurement circuit
- Rice mill circuit
- Agricultural small tractor lighting circuit
- AC voltmeter
- Diode square rate detection circuit
- collector amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
- High and low frequency signal generator circuit
