Counting circuit composed of transistors
Source: InternetPublisher:酷到被通缉 Keywords: Transistor counting circuit BSP permanent magnet Updated: 2020/03/25
It can be used in equipment such as paper machines for detection and counting. When the magnet sweeps across L with the rotation of the drum
, an electric potential (i.e., a signal) is induced in L, VTi is
turned on, VT2 is turned off, and relay KA loses power and is released. When the working line speed of this switch
is 0.48-9.9m/s, the response distance
is 15~55mm.
In the figure, the inductor L is wound with 6500 turns of
enameled wire with a diameter of 0.06mm on a permanent magnet . The permanent magnet
is
a paper end positioning magnet (ferrite) adsorbed on the side of the paper drum.
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Why do we need a MOSFET gate resistor? MOSFET Gate Resistor Placement
- How are diodes made using semiconductors?
- This article will tell you the hard requirements of operational amplifiers
- Share a Motorola amplifier circuit
- Make a flameless electronic candle using simple electronics and LEDs
- Make a simple AM radio with digital circuit
- LED Bicycle Lights
- Experiment and production of NE555 time base integrated circuit
- Inpatient pager circuit
- Agricultural spraying and insecticide control circuit
- Egg heating control circuit
- Poultry warming temperature control circuit
- Soil water shortage prompt circuit
- AC voltmeter
- Integrated synchronous detector composed of analog multiplier MC1596
- Crabo oscillator circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Digital stopwatch display circuit
