SL322C level drive display circuit and pin arrangement
Source: InternetPublisher:酷到被通缉 Keywords: Display circuit BSP Updated: 2020/12/27
The level driven display can display it with light according to the size of the level input signal. There are two commonly used ones: SL322C and
SL323.
This circuit contains two sets of independent level drive indicators with completely consistent performance. Each group can be used independently to
drive 5 light-emitting diodes respectively; they can also be used in series or cross-series with each other to drive 10 light-emitting diodes. It is suitable for indicating the volume level in cassette recorders and home audio equipment, and can also be used for indicating the voltage
level
in special instruments and automatic control equipment .
Main electrical parameters: Maximum operating voltage is 18V, static power supply current ≤ImA (no input) and ≤280mA
(input level is 6V); lighting level is when the first lamp is on (≤1V), and both sets of lamps are on when connected in parallel (≤4V).
The SL322C level drive display circuit and pin arrangement are as shown in the figure
- Symbol/working principle/type/characteristics/application scenarios of depletion-mode MOSFET
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- RC filter explained in detail
- What is the difference between CPLD and FPGA?
- How to calculate the value of capacitors in parallel?
- What is a D flip-flop and how does it work?
- DIY a decorative lamp
- Important things to know about PCB routing and how to design the right routing for your PCB
- Summary of knowledge points of multiplexer
- Star finder battery indicator circuit
- Agricultural temperature control circuit
- Rice mill circuit
- Agricultural small tractor lighting circuit
- Straw returning to field crusher circuit
- AC voltmeter
- Varactor Diode Frequency Modulator
- Capacitive feedback oscillator circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Digital stopwatch display circuit
- Various signal generator circuits
