Output voltage expansion circuit b
Source: InternetPublisher:王达业 Keywords: Output voltage BSP operational amplifier Updated: 2021/12/27
The allowable output voltage and maximum output power of the operational amplifier are limited, and are specified in the technical specifications of the operational amplifier
. For example, the maximum output voltage of F007 is ±12V, and the static power consumption is ≤150mW. In some cases it is not large enough,
so an expansion circuit must be used. The
common output voltage expansion circuit is shown in the figure
- Voltage divider circuit calculation formula, where to find the voltage divider circuit?
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What is the difference between single-phase and three-phase power? When is three-phase power required?
- An article explains the working principle of the Wheatstone bridge
- Which TVS diodes are suitable for RS232/RS485 and Controller Area Network applications?
- Analysis of the working principle of CMOS/CCD image sensor
- What is power factor and three ways to improve it
- Why use PWM? What are its advantages?
- Structural diagram and function of sliding resistor
- What is a Demultiplexer
- Homemade disinfectant circuit
- Electronic anti-asthma circuit
- Fish pond oxygenation reminder circuit
- Peanut and melon seeds roasting machine circuit
- Straw returning to field crusher circuit
- Greenhouse temperature control circuit
- Egg heating control circuit
- Double gate field effect transistor high frequency amplifier circuit
- Guest arrival signal recognition circuit
- Home appliance repair signal generator circuit
