Autotransformer AC stabilized power supply circuit driven by SL322 driver
Source: InternetPublisher:spectrum Keywords: AC stabilized power supply autotransformer driver stabilized power supply circuit Updated: 2020/02/25
This voltage regulator is suitable for use in areas with low voltage. The load capacity
is determined by the relay contact capacity and the capacity of the transformer Ti, and is generally used for small power loads. This circuit uses a 22016V, 5~10W transformer
(T2) and SL322 light-emitting diode driver (A) as a driver. It can be used for voltage light display and can also drive a
relay as a voltage regulating switch.
- Build a simple buck-boost regulator and test it on a breadboard
- Schematic diagram of car cigarette lighter to USB power port
- Introduction and principle analysis of switching regulated power supply
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Dual forward converter schematic diagram
- A novel and practical DC low voltage stabilized power supply
- Homemade low-power UPS
- Constant current charger using light emitting diode as voltage regulator
- Self-made high-stability, high-current, DC adjustable voltage-stabilized power supply using operational amplifier
- Homemade Electric Bike Fast Charger
- Laser power circuit
- 3v to 5v circuit diagram
- Voltage stabilization control circuit in power circuit
- 4-phase CPU power circuit using HIP6301 and HIP6602 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Transistor-driven AC regulated power supply circuit
- One of the relay-controlled autotransformer AC stabilized power supply circuits
- Timing switch AC power circuit
- CF1 (CF2) DC power supply circuit
- Common power circuits and applications 09
