Typical circuit of three-terminal fixed stabilizerb
Source: InternetPublisher:sigma Keywords: wiring op amp Updated: 2021/05/31
Three-terminal fixed integrated voltage regulators are divided into two series: 7800 positive voltage regulator and 7900 negative voltage regulator. When the difference between the output voltage (that is, the regulated voltage value)
reaches 0. 8V, it can maintain its operating characteristics. This is due to the unusual connection method adopted by operational amplifier
A.
There are many types of voltages from 5 to 24V, and the output current is all 1.5A. For example, model 7805 has a +5v output, and model 7912 has a -12V output. The voltage
regulator has overcurrent, overheating and safe working area protection inside to prevent the voltage regulator from being damaged due to overload. The typical
wiring and appearance of the three-terminal fixed voltage regulator are shown in Figure 14-51. The capacitor Cl can generally be selected according to the capacity of 1000y, F per 0.SA current.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Benefits of Wide Bandgap Technology for Power Converters
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Dual forward converter schematic diagram
- Adjustable regulated power supply with current limiting protection
- A novel and practical DC low voltage stabilized power supply
- Electric bicycle battery charger circuit
- Constant current charger using light emitting diode as voltage regulator
- The production of adjustable voltage-stabilized power supply composed of LM317
- Three-phase three-wire active energy meter direct connection circuit
- Single-phase active energy meter wiring with current transformer
- Radial wiring power supply circuit b
- Wiring of the power supply part of the microcontroller
- Lightning protection wiring for substations above 6300kV·A
- Lightning protection wiring c for direct distribution generators from 300 to 1500kW
- Wiring d when the leakage protector supplies power and lighting loads in the TN system
- Wiring c when the leakage protector supplies power and lighting loads in the TN system
- Wiring b when leakage protector supplies power to unbalanced load in TT system
- Voltage transformer VV junction box commutation switch access circuit
