Concentrated Typical Circuit for Reference Voltage d
Source: InternetPublisher:已注销 Keywords: reference voltage voltage regulator tube Updated: 2020/11/29
Several typical circuits that use voltage regulator tubes to obtain reference voltages are shown in Figure 14-15. Figure 14-15 (a) and (b) have slightly poorer circuit stability
, Figure 14-15 (c) has higher stability, and Figure 14-15 (d) shows the high-stability reference voltage .
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- How about the boost converter TPS61299?
- Build a simple buck-boost regulator and test it on a breadboard
- Energy-saving motorcycle rectifier regulator
- Basic circuit description of adjustable voltage regulator LM317
- Recommended circuits for different power on times of LM4911
- The constant current source composed of two transistors can drive high power
- Principles and precautions of active discharge circuit
- An ultra-low output voltage regulator
- The production of adjustable voltage-stabilized power supply composed of LM317
- 24V power supply pure flat display high voltage power supply circuit diagram
- Laser power circuit
- Industrial product promotion and shopping guide DC power supply circuit
- Output 12V-10A power supply circuit
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- Simple reference voltage generation circuit using shunt regulator
- Class A power amplifier power circuit
- ±15V active servo power circuit
- Common power circuits and applications 01
- Inverter power circuit made with BJ50A
