High voltage pulse warning grid
Source: InternetPublisher:拿铁三分糖 Keywords: Power grid high voltage pulse BSP single junction transistor Updated: 2021/08/13
It can output tens of thousands of volts of high-voltage pulse voltage, which is adjustable from dozens to hundreds of times per minute
(by adjusting the potentiometer RPi). Each pulse has a power of about 12mA and a discharge energy of less than 4J. It can also alarm when there is a fault discharge
It uses a single-junction transistor relaxation oscillator as a trigger circuit. Cs is the energy storage capacitor. SB is the alarm release button. Transformer
T2 can be used with TDJ-6/0. lkV or 10/0. lkV, 640V. A voltage transformer is used instead, with one end of the secondary connected to ground.
- Build a Bluetooth-controlled wireless scoreboard
- One-digit display
- LED Flasher circuit using 2 transistors for LED switching
- Use MC1455PIG to make automatic cycle light-emitting diode circuit
- Mains undervoltage and overvoltage protection circuit 2
- Microwave Doppler warning circuit
- Chandelier brightness controller circuit using thyristor
- Electronic rapid starter for fluorescent lamps
- Four color light circuit
- Night target display circuit diagram
- electromagnetic field sensor
- Self-defense anti-riot circuit
- Electric massager circuit
- Agricultural temperature control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Varactor Diode Frequency Modulator
- Integrated synchronous detector composed of analog multiplier MC1596
- Simple AGC circuit in transistor radio
- Audio function generator composed of ICL8038
- common emitter amplifier circuit
