After a power outage, it is prohibited to reconnect the circuit when a call comes in b
Source: InternetPublisher:风向西瓜 Keywords: relay noise switch Updated: 2020/07/04
It is forbidden to reconnect the circuit
when a call comes after a power outage. This can avoid
accidents caused by forgetting to turn off the electrical appliances and power grid in use when the power comes back again . It can be easily implemented using relays or contactors, as shown in Figure 13-77 (a), but the relay coil
consumes power, and when the load power is large, contactor control is required, which is bulky and noisy . If
a bidirectional thyristor is used as a contactless switch , the problem can be solved.
- One-digit display
- DIY a hat with a programmable LED display
- IR2153 emergency fluorescent lamp circuit diagram
- DCD-1240 multifunctional rechargeable lighting
- A light fence circuit diagram with LDR
- Use NE555 to make a lighting and sound changing circuit
- One of the bead-type emergency light circuits
- Infrared remote control dimmer light circuit
- Electronic music dimming desk lamp circuit
- Digital display multi-function thermometer circuit
- Three primary color display circuit
- Photoelectric detection anti-theft alarm circuit
- Sock knitting machine fault shutdown circuit
- One light one switch lighting circuit
- TN-S power supply mode circuit
- Anti-shake circuit using RS flip-flop
- additional preamplifier
- Power frequency noise double T filter circuit
- Microphone low noise voice preamplifier circuit diagram
- RF noise bridge
