Small DC motor irreversible speed regulation circuit 4
Source: InternetPublisher:jikai233 Keywords: DC motor reversible speed regulation speed regulation circuit BSP Updated: 2021/01/09
It is controlled by two thyristors and is suitable for occasions with low accuracy requirements. Adjusting the potentiometer
RPi can change the amount of voltage negative feedback; adjusting RPa can change the sensitivity of the device (too high a sensitivity can easily cause oscillation
); adjusting the master potentiometer RPz can change the speed of the motor.
- How to use a microcontroller to control a servo motor?
- Servo motor pin diagram/working principle/application
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Motor self-starting circuit
- Using P110C to control 6 DC motors simultaneously
- Methods for Eliminating Noise of Brushed DC Motors
- Light-controlled circuit design and analysis
- Temperature control circuit design and analysis
- Electric vehicle battery charging protection circuit
- Motor forward and reverse control wiring diagram (2)
- Set timing circuit when power is on
- strain sensor
- stuttering correction circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- ring amplitude modulation circuit
- Capacitive feedback oscillator circuit
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Motorcycle flash light circuit
