Internal wiring of single-phase rectifier intelligent control module
Source: InternetPublisher:张七岁 Keywords: Wiring rectification intelligent control control module Updated: 2021/07/28
The thyristor intelligent control module is highly integrated with the thyristor main circuit and phase shift control circuit, and has power control function.
Large-size modules also have protection functions such as overheating, overcurrent, and phase loss.
(1) Internal wiring of single-phase rectifier intelligent control module
- How to use a microcontroller to control a servo motor?
- Use your smartphone to turn on/off the power in your home
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- Perform surgery on the speaker protection circuit
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Using P110C to control 6 DC motors simultaneously
- Simple phase failure protection circuit composed of intermediate relay
- Design and manufacture of three-phase motor protection circuit
- Electric vehicle battery charging protection circuit
- Precious home appliance anti-theft alarm
- MM36SB020 two-wire wiring circuit diagram
- Three-phase four-wire active energy meter direct-entry wiring diagram
- Lightning protection wiring of 3150 to 6300kV·A substation
- Lightning protection wiring c for direct distribution generators from 300 to 1500kW
- Y, y connected transformer lightning protection wiring
- Lightning protection wiring of transformer connected by Y and yn
- Wiring d when the leakage protector supplies power and lighting loads in the TN system
- Wiring b when leakage protector supplies power to single-phase load in TN system
- Wiring b when leakage protector in TN system supplies three-phase balanced load
- Typical circuit of three-terminal fixed stabilizer a
