Several trigger circuits using resistor-capacitor phase shifting b
Source: InternetPublisher:宋元浩 Keywords: Trigger circuit resistor-capacitor phase shift BSP Updated: 2021/05/31
The trigger circuit introduced above for unidirectional thyristors is also applicable to bidirectional thyristors. Also listed below are some for bidirectional
circuits as shown in Figure 16-28. Figure 16-28 (a) and (b) are direct trigger circuits; Figure 16-28 (c) is a trigger circuit using a
bidirectional trigger diode; Figure 16-28 (d) is a trigger circuit using two light-emitting diodes connected in reverse parallel Trigger circuit; Figure
16-28 (e) is a trigger circuit using neon bulbs; Figure 16-28 (f) is a trigger circuit using two NPN diodes (such as 3DG6, etc.)
; Figure 16-28 (g) is a trigger circuit using The trigger circuit of two diodes connected in reverse parallel; Figure 16-28 (h) is the trigger circuit
using
a triode instead of the bidirectional trigger diode ; Figure 16-28 (1) is
the trigger circuit circuit.
- How to use a microcontroller to control a servo motor?
- How to build a simple tachometer using an infrared reflectance sensor
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- What is a RADAX motor?
- Squirrel cage asynchronous motor reverse braking control circuit
- Methods for Eliminating Noise of Brushed DC Motors
- Temperature control circuit design and analysis
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Bicycle anti-theft alarm
- Excellent performance household inverter power supply circuit
- Analysis of rectifier circuit types and principles
- Pulse therapy circuit
- Peanut and melon seeds roasting machine circuit
- Crop anti-frost circuit
- Rural fish farming control circuit
- Rural vegetable greenhouse lighting circuit
- Poultry warming temperature control circuit
- Simple AGC circuit in transistor radio
- High and low frequency signal generator circuit
