Zero trigger integrated circuit temperature control circuit 2
Source: InternetPublisher:张小哥 Keywords: Trigger integrated circuit temperature control circuit BSP Updated: 2021/06/09
It is a current zero trigger circuit using KJ008 or KC08 integrated circuit
to achieve
automatic temperature control.
In the figure, the synchronization voltage is taken from the second electrode of the triac V. When the load current is zero, V is off. In this circuit
, when the furnace temperature is lower than the set value, as long as the potential of pin 2 is lower than the potential of pin 4, a pulse can be output when the load current crosses zero
, triggering the bidirectional thyristor to turn on; otherwise, the bidirectional thyristor will turn off. , thereby achieving the purpose of AC voltage regulation.
- How to choose the right level of integration to meet motor design requirements?
- Model rocket launch controller circuit
- Controlling LEDs with Node-RED in Raspberry Pi
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How can we make the robot move precisely on a predefined path?
- What are the challenges in designing a permanent magnet linear generator?
- Squirrel cage asynchronous motor reverse braking control circuit
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Design and production of wireless multi-location control switch circuit
- Motorcycle anti-theft device circuit design
- Straw returning to field crusher circuit
- Soil water shortage prompt circuit
- Farmland irrigation automatic control circuit b
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Simple AGC circuit in transistor radio
- Second-order active band-stop filter circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Power phase sequence display circuit
- Digital stopwatch display circuit
