Zero trigger thyristor temperature control circuit 4
Source: InternetPublisher:张七岁 Keywords: Thyristor trigger temperature control circuit BSP Updated: 2020/03/10
It uses yPC1701C integrated circuit (zero voltage control switch). The temperature measuring element is
a thermistor Rt with negative temperature coefficient.
The characteristic of the yPC1701C (A) circuit is that it can generate DC voltage by itself, and
cooperates with the external resistor R4, diode VD and capacitor C to form a DC voltage between pins 8 and 5 for use by the chip.
RPz is the sampling resistor, adjustable to 120kCI. Adjust the potentiometer RPi to change the temperature set value.
- How to use a microcontroller to control a servo motor?
- Build a Smart Garage Door Opener Using a Raspberry Pi
- Peripheral circuit of automotive motor controller power supply chip
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Hydraulic control circuit design and analysis
- Design and production of wireless multi-location control switch circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- "Watchdog" anti-theft alarm circuit
