Liquid level automatic control circuit using MC14011 integrated circuit
Source: InternetPublisher:常思一二 Keywords: integrated circuit nand gate electrode Updated: 2021/10/24
It uses MC14 011 four NAND gate integrated circuit, which has simple circuit and reliable action. It
is a flood-type water level automatic control circuit. When the water level drops below electrode B, NAND gate D4 outputs low level , the RS flip-flop composed of NAND gates
D1 and D2 is triggered to flip, NAND gate 'D3 outputs high level, transistor VT is turned on, and the relay
KA and contactor KM are closed, and the water pump starts to fill the water tank; when the water level rises to electrode A, pin 1 of the integrated circuit
becomes
low level, RS flips, Da outputs low level , VT is cut off, and KA and KM are released. , the water pump stops filling.
- A simple magnetic switch circuit sharing
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to make a wheeled self-balancing robot using ultrasonic sensors
- An automated model railroad layout project using a microcontroller
- Squirrel cage asynchronous motor reverse braking control circuit
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Temperature control circuit design and analysis
- Simple three-phase motor phase loss protection circuit
- Ultra-short wave item left behind reminder alarm
- "Watchdog" anti-theft alarm circuit
- Circular light control circuit
- fire smoke control circuit
- Ultrasonic transmitter circuit b composed of UCM-40-T and 74LS00 NAND gate
- Water dispenser double sheet control circuit
- Car window control circuit
- High-rise residential walkway lighting control circuit
- PLC light source robot hand bubble control circuit
- Relay control circuit a
- Parking and incoming call alarm circuit (3)
- Two-input transistor NAND gate circuit
