Electromagnet overcurrent protection circuit
Source: InternetPublisher:toothache Keywords: Protection circuit electromagnet overcurrent protection BSP Updated: 2020/01/01
Once the armature of an AC electromagnet is blocked, the magnetic gap increases, the inductance is greatly reduced, and the coil current will reach 6 to
8 times the rated current. If not discovered in time, the electromagnet will be easily burned out. Therefore, in places with harsh operating environments or important occasions, it is necessary
to install protective devices for electromagnets.
Figure 6-61 is a simple electromagnet overcurrent protection circuit .
Resistor R can be selected according to the following formula:
R=UR/I. (n), power PI. In the formula R(W)
, UR - the voltage drop on the resistor R. When the rated operating voltage of the sensitive relay is 12V, UR can be 1.5-2V
. If the operating voltage is 24V, R can be 3-4V.
J. ——The rated current when the electromagnet is in the closed state. A.
- How to use a microcontroller to control a servo motor?
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- How to remotely control devices using ESP8266 and LPC2148
- How to Make a Simple Chicken Incubator
- Tutorial for building a remote-controlled Arduino Air-Boat
- A small improvement to the temperature and water level indicator alarm
- Simple phase failure protection circuit composed of intermediate relay
- Design and analysis of a four-bit remote control component capable of remote reset
- Do-it-yourself trial production of phase failure protection device
- Motor forward and reverse control wiring diagram (2)
- Electric massager circuit
- Electronic anti-asthma circuit
- Rice mill circuit
- Rural fish farming control circuit
- Greenhouse temperature control circuit
- Integrated synchronous detector composed of analog multiplier MC1596
- base amplitude modulation circuit
- ring amplitude modulation circuit
- Sawtooth wave generator circuit (1)
