Fast response circuit with contact control
Source: InternetPublisher:风向双子座 Keywords: contacts electromagnets Updated: 2020/11/16
After the DC electromagnet (such as electromagnetic decoupler, solenoid valve, etc.) is powered on, due to the self-inductance of the coil, the current
rise rate is limited, causing the electromagnet to attract slowly. In order to improve the attraction speed of the electromagnet, in addition to the strong excitation method,
some improvements can be made to the peripheral circuit without changing the structure of the DC electromagnet to achieve the actual requirement of fast response on and off
The circuit is shown in Figure 6-14. It uses a freewheeling diode VD on the valve electromagnet coil. This plays
a role in quickly extinguishing the arc. This circuit is only suitable for occasions where the on-off time requirement is not high. If the on-off time is on the millisecond level, the electromechanical inertia of the contact
control itself cannot be increased, and arcing occurs between the contacts , so that the solenoid valve cannot be guaranteed to be on and off reliably.
- The meaning and importance of circuit protection, common types of circuit protection
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- DIY an electromagnetic levitation device
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- Temperature control circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- Guanghua brand anti-theft doorbell electronic lock circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Homemade short circuit alarm device
- Rural fish farming control circuit
- Water dispenser double sheet control circuit
- Table printing machine control circuit
- PLC chain alarm control circuit used in production process
- Multi-pole leakage protector circuit a
- Photoelectric output control circuit
- Electric heater temperature detection control circuit
- Forward and reverse control circuit of micro DC motor a
- Temperature detection control circuit for vegetable greenhouses
- Inverter brightness control circuit
