Bead-type emergency light circuit 2
Source: InternetPublisher:fish001 Keywords: Emergency lights TI BSP Updated: 2021/04/15
When the mains power is normal, the transistors VTi and VT2 are cut off, and the bead bulb EL does not light up. When the mains power fails
, VTi is turned on by obtaining the base bias voltage from the battery through resistors R2 and Ra, Vtz is turned on, and the lamp EL lights up automatically.
- Working Principle of CCFL and Analysis of Electronic Driving Circuit
- A light fence circuit diagram with LDR
- Design and production of digital number answering machine
- Driving circuit for driving light-emitting diodes by IR53HD420
- Infrared remote control device circuit
- Mains undervoltage and overvoltage protection circuit 2
- Microwave Doppler warning circuit
- Chandelier brightness controller circuit using thyristor
- WT8089 holiday lights ASIC
- Shock resistant soft start constant current LED lighting circuit
- Electronic thermometer circuit
- Egg warming circuit
- Mixer built with analog multipliers
- Simple AGC circuit in transistor radio
- Wien bridge oscillator circuit
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- color discrimination circuit
- High and low frequency signal generator circuit
- Guest arrival signal recognition circuit
