One of the incandescent lamp dimming circuits using thyristors b
Source: InternetPublisher:念念Brown Keywords: Thyristor incandescent lamp dimming circuit BSP Updated: 2021/11/07
(1) One of the incandescent lamp dimming circuits using thyristors.
The circuit is shown in Figure 2-66. Figure 2-66 (a) Using the method of combining thyristor half-
wave controllable dimming and diode dimming. When the switch SA is turned
to the "3" position, adjust the potentiometer RP, and the voltage at both ends of the bulb
changes in the range of 20-100V; when SA is turned to the "2" position,
the bulb emits light at a brightness of approximately 1/4 of the rated power; When SA hits the "1" position
, the bulb is fully lit. Figure 2-66(b) only uses pin-gate dimming, and a light bulb with a rated voltage of 11V can be used.
- Fire safety evacuation emergency signs
- Six LED stereo VU display circuit built with IC LM3915
- A light fence circuit diagram with LDR
- Infrared detection alarm
- Driving circuit for driving light-emitting diodes by IR53HD420
- battery charging circuit
- Gas and smoke alarm circuits with intermittent alarms
- Remote anti-theft alarm
- Electronic rapid starter for fluorescent lamps
- Photoelectric adjustment circuit
- Agricultural temperature control circuit
- High-efficiency speaker circuit for rural stage
- Crop anti-frost circuit
- Straw returning to field crusher circuit
- Agricultural spraying and insecticide control circuit
- Farmland drainage automatic control circuit
- Diode Balanced Mixer Circuit
- Varactor Diode Frequency Modulator
- collector amplitude modulation circuit
- Wien bridge oscillator circuit
