Use LM317+TL081 to make a 0-12V/3A adjustable regulated power supply
Source: InternetPublisher:拿铁三分糖 Keywords: LM317 TL081 adjustable regulated power supply Updated: 2023/12/05
Usually our power supply cannot be adjusted from zero volts. The circuit introduced here can be continuously adjusted from 0-12 volts. The circuit is simple, easy to obtain materials, and easy to copy. It is very suitable for amateur electronics enthusiasts to use as experimental power supplies. The device parameters can refer to the values shown in the figure. The transformer should have sufficient capacity according to the output power.
- How does a step-down switching regulator use a series transistor or a power MOSFET?
- How to ensure the stable performance of SSD when the voltage is unstable?
- Energy-saving motorcycle rectifier regulator
- Basic circuit description of adjustable voltage regulator LM317
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Driving circuit that controls LED brightness using PWM signal
- Dual forward converter schematic diagram
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Electric bicycle battery charger circuit
- Power circuit of STR5412
- Power supply circuit design optimized for digital light projectors
- Typical Reference Voltage and Power Supply Circuits
- Output adjustable voltage stabilized power supply circuit
- Basic application circuit of LM31704
- Constant current parallel voltage stabilized power supply circuit diagram composed of LM317
- DIY power supply with current limiting gear and adjustable voltage
- Electromagnetic current-limiting adjustable voltage-stabilized power supply circuit
- High stability power supply circuit diagram using LM317
- Low temperature coefficient adjustable regulated power supply
