TDA7000 single chip FM radio circuit diagram
Source: InternetPublisher:王达业 Keywords: TDA7000 FM radio Updated: 2023/12/06
TDA7000 single-chip FM radio circuit diagram. The circuit is very simple. The resonant inductor can be wound around 5 turns on a 5 mm diameter plastic rod using 0.5 mm enameled wire. The telescopic turn spacing makes the adjustment range conform to the FM band. The circuit uses high-impedance headphones. Of course, you can also add one level of amplification and use ordinary headphones.
- Share the features of Wi-Fi 6 that you don’t know
- DIY a network router
- LM386 makes an AM radio
- Homemade modified machine with 4 LNB inputs and audio and video outputs
- The production of a crystal oscillator frequency-controlled broadband FM transmitter
- FM microphone made by 9018
- Superheterodyne receiving module circuit using RX3310A
- MICRFl04 ASK 470~300 MHz Transmitter
- RF2948B QPSK 2.4 GHz Spread Spectrum Transceiver
- T5761/T5760 ASK/FSK 870~868 MHz/928~902 MHz Receiver
- Small FM radio circuit
- USB communication circuit
- Indoor unit communication circuit
- Integrated AM and FM radio circuits for household appliances
- High quality AM/FM radio circuits
- AM/FM radio circuit using three integrated circuits
- Can type FM radio circuit diagram
- Two-way communication circuit circuit diagram
- Long distance serial communication circuit
- Circuit diagram of stock information receiver modified from ordinary FM radio
