Three working states of transistors - PNP type - cut-off state
Source: InternetPublisher:通通 Keywords: Transistor BSP collector Updated: 2020/07/04
Cut-off state:
When "≤0", the collector current is very
small, the transistor is equivalent to cut-off, and the power supply
voltage mound is almost entirely applied to both ends of the tube.
Amplification state:
"Gradually increasing from O, the collector current
J also increases according to a certain proportion. A small
change in I causes a large change. The transistor
plays an amplifying role.
Saturation state:
When the three-input tube is saturated, the voltage drop across the tube is very
small, and almost all of the power supply voltage E is applied to the collector
load. The larger the I port at both ends of the collector load resistor, the more
sensitive the control.
- IRS2530D electronic ballast circuit diagram
- Laser detection and indicating device system circuit design
- Design and production of rain control and light control timing controller based on P87LPC764
- Application circuit of CAT3606
- Two-way electronic music doorbell circuit
- Automotive LED driver circuit diagram using LT3486
- Electronic rapid starter for fluorescent lamps
- Incandescent lamp dimming circuit using thyristor part 4a
- Mains undervoltage and overvoltage alarm circuit 2
- Touch lighting switch circuit three
- Excellent performance household inverter power supply circuit
- High-efficiency speaker circuit for rural stage
- Agricultural small tractor lighting circuit
- Mixer built with analog multipliers
- Integrated synchronous detector composed of analog multiplier MC1596
- Simple AGC circuit in transistor radio
- Wien bridge oscillator circuit
- OTL low frequency power amplifier circuit
- Differential Amplifier Circuit
- Home appliance repair signal generator circuit
